How do I keep Firefox from trying to update?
  • 4 replies
  • 2 have this problem
  • 6 views
  • Last reply by user66338
Whenever I try to open Firefox my Windows warning will appear saying Firefox updater wants to install something. I currently have "never check for updates selected", so why isn't Firefox following this? My version is 12 and I have no desire to update to 13.
All Replies (4)
Note: Turning off the automatic update of Firefox is not recommended. Only the latest version of Firefox gets regular security updates and will keep you safe and sound on the internet.
However, if you really need to turn off the automatic update of Firefox, please follow these steps: In the Firefox window, click the Firefox button at the top, then select the Options menu item.
  1. If no Firefox button is shown, click the Tools menu at the top of the menu bar, then select Options.
  2. From the Options window, click the Advanced panel.
  3. In the Advanced panel, click the Update tab.
  4. Under Firefox updates, select Never check for updates.
  5. Now click the OK button to apply the changes.
That's the problem - I've already done that and Firefox is still trying to automatically update!
Application Basics
       Name
       Firefox
       Version
       12.0
       User Agent
       Mozilla/5.0 (Windows NT 6.1; WOW64; rv:12.0) Gecko/20100101 Firefox/12.0
       Profile Directory
         Show Folder
       Enabled Plugins
         about:plugins
       Build Configuration
         about:buildconfig
       Crash Reports
         about:crashes
       Memory Use
         about:memory
 Extensions
       Name
       Version
       Enabled
       ID
       McAfee ScriptScan for Firefox
       14.4.1
       false
       {D19CA586-DD6C-4a0a-96F8-14644F340D60}
       McAfee SiteAdvisor
       3.4.1.195
       false
       {4ED1F68A-5463-4931-9384-8FFF5ED91D92}
 Important Modified Preferences
     Name
     Value
       accessibility.typeaheadfind.flashBar
       0
       browser.cache.disk.capacity
       1048576
       browser.cache.disk.smart_size.first_run
       false
       browser.cache.disk.smart_size_cached_value
       1048576
       browser.places.smartBookmarksVersion
       2
       browser.startup.homepage
       http://www.google.com/
       browser.startup.homepage_override.buildID
       20120420145725
       browser.startup.homepage_override.mstone
       rv:12.0
       browser.zoom.full
       false
       extensions.lastAppVersion
       12.0
       network.cookie.prefsMigrated
       true
       places.database.lastMaintenance
       1339396488
       places.history.expiration.transient_current_max_pages
       104858
       privacy.sanitize.migrateFx3Prefs
       true
       security.warn_viewing_mixed
       false
 Graphics
       Adapter Description
       NVIDIA GeForce GTX 560 Ti
       Vendor ID
       0x10de
       Device ID
       0x1082
       Adapter RAM
       1280
       Adapter Drivers
       nvd3dumx,nvwgf2umx,nvwgf2umx nvd3dum,nvwgf2um,nvwgf2um
       Driver Version
       8.17.12.9573
       Driver Date
       2-9-2012
       Direct2D Enabled
       true
       DirectWrite Enabled
       true (6.1.7601.17789)
       ClearType Parameters
       ClearType parameters not found
       WebGL Renderer
       Google Inc. -- ANGLE (NVIDIA GeForce GTX 560 Ti) -- OpenGL ES 2.0 (ANGLE 1.0.0.963)
       GPU Accelerated Windows
       3/3 Direct3D 10
       AzureBackend
       direct2d
I cannot find anything in your system information that would indicate that the value for updating was ever changed.
Please do the following:
  1. Enter about:config in Firefox and press Enter.
  2. Dismiss the warning that appears.
  3. Set app.update.auto and app.update.enabled to false.
See if that helps!
